ISO 9001:2015
Certified QMS
AS9100D and ISO 13485:2016 Manufacturers
NADCAP, and NABL Approved Manufacturing Partners
FAIR Available and
Inspection Reports with Every Order
COAs and COCs Available
A Global Network of High Volume CNC Machining Services
Global network of cnc machining
Tight tolerances as low as +/- 0.0003″
Virtually unlimited finishing capabilities.
Efficient cost & lead times.
Precision high-volume, mass-production CNC parts.
Advanced Technologies
Our machines are equipped with advanced technologies that reduce downtime between machining cycles, ensure consistent quality, and reduce the manual labor involved.
Multi-axis machining systems
Automation systems
  • Robotic machine tending
  • Vision and inspection systems
  • Automatic packaging systems
  • Automated tool changers
Premium class of controls
High-end cutting tools
Smart factory integrations
  • IoT integration
  • AI-powered process optimization
  • Cloud-based CNC software
  • Real-time data analytics
Materials Finishes
60+ Certified Materials and Finishes
When working with high volumes, material selection is especially critical. Factors such as machinability, strength, and cost-effectiveness have a significant impact on the overall cost and lead time. While CNC machining offers a broad spectrum of material options, it’s important to do thorough research when selecting the best material for your application as you scale up in volume.
When it comes to high-volume machining, Fictiv consistently ensures high quality and helps you choose the right finishing options for high-volume production with one-stop solutions. Several finishing options are available for machined parts.
See all Materials and Finishes
Still not sure which material to select? Try Materials AI.
What is High-Volume
CNC Machining?
High-volume CNC machining is an ideal option for applications that require high-precision parts in large quantities for mass production. This method of large-scale subtractive manufacturing has become even more advantageous with the advancement of technologies that reduce lead time and cost by increasing efficiency.
Fictiv specializes in delivering high-volume CNC machining services with industry-leading speed, precision, and scalability. Leveraging a global manufacturing network, we offer capabilities like multi-axis, ultra-precision, and advanced automation CNC machining. Our expertise facilitates the efficient production of complex parts in large quantities while maintaining tight tolerances, repeatability, and delivery in as little as two days.
Industry Applications
High-volume CNC machining enables precise mass production and can be tailored for desired lead time and cost efficiency.
Automotive Industry
Automotive
Engine components, transmission parts, and other precision parts that require mass production.
Aerospace
Aircraft parts such as brackets, bushings, and turbine components that meet strict tolerances.
Medical Devices
Mass production of medical tools, devices and instruments, prostheses, and implants with precise specifications.
Consumer Electronics
Electronic housing components, connectors, and other small parts that are produced in large volumes.
Industrial Equipment
High-volume production of components used in heavy machinery and industrial systems like gears, sprockets, shafts, and bearings.
High-Volume CNC vs. Low-Volume CNC
The primary difference between high-volume and low-volume CNC machining
is in production scale and efficiency.
High Volume CNC parts production
High-Volume CNC Machining
Streamlined processes and operations for mass production
Repeatibility is key: large quantities of identical parts at max efficiency
Tooling setups are streamlined for reduction in tool changes and wear
VS
Low Volume CNC parts
Low-Volume CNC Machining
Small-batch production or prototyping
Flexibility, customizability, and precision are paramount
Custom setups or tooling adjustments may be required for complex projects
Advantages of High-Volume CNC Machining
High-volume CNC machining has many advantages, including machining speed, quality, and overall efficiency.
Cost Efficiency
Bulk material purchase. Lower cost per part.
Repeatability and Reliability
Advanced tooling and fixtures.
Production Efficiency
Precision Tolerances
Tolerances as low as +/- 0.0001”.
Faster Lead Times
One-stop-shop for rapid CNC machining and finishing.
Scalability and Flexibility
From prototype to production, and everything in between.
Learn how Honeywell drove 7x faster development with Fictiv.
“They do an incredible job connecting my needs as a customer to those suppliers that have the capability, the right competitive cost, and the capacity to build my product and get it to me in a very rapid cycle time.” Read Full Case Study
JOHN HOBGOOD
JOHN HOBGOOD
Vice President, Advanced Manufacturing and Automation
Get A Quote Now
