Compression Molding Services
Experience lower tooling costs than injection molding with high-quality, durable parts.
Access to a Fortune-500 global supply chain
9 Certified Materials, 3 Post Processing Options
Material Certification, Certificate of Compliance, Advanced Inspection
Hardware Installation, Mechanical Assembly
Try Materials.Ai
MaterialsAI
ABS
Process:
FDM 3D printing
Colors:
Resolution:
0.25 mm
Max Print Size:
914 x 609 x 914 mm
Precision Molded Tolerance
With Drawing Without Drawing
Linear Dimension +/- 0.01 mm
+/- 0.004 inch
SPI Commercial
Hole Diameters +/- 0.005 mm
+/- 0.002 inch
SPI Commercial
Part lengths of up to 1000mm*600mm available on our platform, process dependant. Please inquire about anything larger.
Tolerances listed here are minimums for an ideal case. Looser tolerances may be required depending on process, material choice, or part geometry.
Compression Molding Finishing Options
All finishes meet SPI standards
Finishes
SPI polished finishes and MT (MoldTech) textured finishes.
Pad Printing
Applying an ink-based, 2D design to a 3D surface.
Color Matching
Standard colors plus matching to Pantone or RAL number.
JOE TEDESCO
JOE TEDESCHO
Lead Aerospace Engineer
Heliospace
Download Case Study >
ANDREW WILLING
Mechanical Engineer
HEBI Robotics
JON HOBGOOD
Unrivaled customer service
"Fictiv does an incredible job connecting my needs as a customer to those suppliers that have the capability, the right competitive cost, and the capacity to build my product and get it to me in a very rapid cycle time."
JON HOBGOOD
Vice President,
Advanced Manufacturing and Automation
Honeywell Aerospace
Get a quote now
Learn More about Compression Molding
The Ultimate Guide to Compression Molding
Compression molding produces parts by placing a pre-measured amount of material into a mold...
Read More >
Blow Molding vs. Rotational Molding: Differences and Comparisons
Blow molding and rotational molding...
Read More >
Compression Molding Versus Injection Molding
Compression molding vs. injection molding is a contest between two of the most popular ways to mold...
Read More >
