Accelerate your product-development process, ensure quality, and transform your ideas into prototypes faster.
ISO 9001 certified,
AS 9100 / ISO 13485 compliant
Every part inspected
by Fictiv Quality Engineers
Parts as fast as 2 days
*Injection molding quotes may take longer
One easy-to-use platform
from quote to delivery
Stereolithography (SLA)
A high resolution, production grade technology
Lead time: 3 days
Resolution: 0.1mm
Max part size: 380x380x255mm
Tolerance: +/- 0.1mm
Materials: Acura 25, Accura ClearVue, Accura 60, Accura Xtreme Grey or White 200
Ideal for functional testing, low to mid volumes.
Lead time: 3 days
Resolution: 0.1mm
Max part size: 340 x 340 x 600 mm (P390) or 700 x 380 x 580 mm (P760)
Tolerance: +/- (0.25 mm + 0.002mm/mm)
Materials: Nylon
PolyJet
Ideal for visual models or functional prototypes.
Lead time: 1 day
Resolution: 0.016 mm
Min part size: 5 x 5 x 5 mm
Max part size: 490 x 390 x 200 mm
Tolerance: +/- 0.2 mm
Materials: Vero, VeroClear, ABS-Like, Rubber-Like
Multi Jet Fusion (MJF)
Accelerate time to market with production-grade 3D printing.
Lead time: 3 days
Resolution: 0.08 mm
Max part size: 380 x 284 x 380 mm
Tolerance: ± (0.3mm + 0.002mm/mm)
Materials: Nylon/ Polypropylene
Low cost process for early stage prototypes
Lead time: 1 day
Min feature size: 1 mm
Max part size: 500 x 500 x 500 mm
Tolerance: +/- 0.5 mm or +/- 1% per inch
Materials: ABS, PETG, PLA, ABS EDS, ASA, PC, PC+ABS
Carbon Digital Light Synthesis (DLS)
Lead time: 1 day
ABS
ABS – M30i
ABS ESD
ABS-Like
Accura 25
Accura 60
Accura AMX Rigid black
Accura ClearVue
ASA
EPU 40
EPU 41
EPX 82
EPX 86FR
FPU 50
Loctite 3D 3843
Loctite 3D IND147
Loctite 3D IND405 Clear
MPU 100
Nylon
Nylon 11 Flame Retardant
Nylon 12
Nylon 6
PA 12 Glass Beads
PC-ISO
PC+ABS
PETG
Polycarbonate (PC)
Polypropylene
RPU 70
Rubber-Like
Somos Evolve
Somos PerFORM
Somos Waterclear
Somos Watershed
ST-130
TPU 88A
Ultem 1010
Ultem 9085
UMA 90
Vero
VeroClear
Source high-quality printed parts through every stage of your development process.
Optimize Infill Density
Improve Thread Strength
Fictiv has a documented manufacturing partner (MP) selection process that is a core competency and differentiates Fictiv from its competitors.
Potential MPs can either apply to Fictiv for selection or Fictiv can approach potential MPs to determine if they are interested in becoming part of the network. The onboarding process starts with a basic questionnaire and then increasing rigor is applied through commercial and quality audits and the production of a complex, tight tolerance test piece. On successful completion of the test piece, the MP is conditionally qualified, although their output is scrutinized as they are ramped-up. All MP performance is tracked and reported on a weekly scorecard. The scorecard positions the MP at a ‘level’ which determines how much work they get offered as an incentive. Other controls ensure that work is offered to the most suitable MPs.
Fictiv’s quality assessment includes a review of how MPs utilize control plans, including the appropriate use of SPC and other statistical controls. Additionally, Fictiv assesses how MPs deal with planned and unplanned changes and special cause events. Fictiv also has a requirement for its MPs to control their externally provided processes, including flowing down the requirements from Fictiv as necessary.
Fictiv provides manufacturing partners with a clear, standardized data package that includes customer-provided 3D models and 2D drawings and Fictiv inspection sheets.
Fictiv has four main methods to verify that parts meet customer requirements:
Fictiv takes full responsibility for the quality of parts manufactured in our ecosystem. When a nonconformance is reported by Fictiv’s Quality Control team, or by a Fictiv customer, email alerts are sent to manufacturing partners in order to resolve the issue and also identify the root cause of the issue to inform the required improvement action reports.
When errors occur and the manufacturing partner submits root causes and improvement actions, we specifically look for the role the control plan plays in both the root cause of the issue and also in the solution to prevent this from recurring.
All parts manufactured with Fictiv undergo inspections by our manufacturing partners, which are then verified by Fictiv either in-person or remotely. Our standard inspections verify critical dimensions using hand tools and cosmetic requirements and we can also perform advanced inspections using CMM or laser scanner technologies as well as first article inspections or other customer inspection plans such as PPAP upon request.
After inspections are completed, all quality documentation is uploaded to the Fictiv platform for customers to easily access at any time through the “Orders” tab of their account. Customers can also view photos of their parts taken at inspection in real-time.
