Zinc Plating
Clear: light blue coating; Black: glossy black coating
Smooth finish, does not hide machine marks
Can be applied with
Media Blasting, Tumbling, Passivation
Color Options
Zinc Plating Black Zinc Plating
Black Zinc Plating
Zinc Plating Clear Zinc Aluminum
Clear Zinc Aluminum
Zinc plating, which is also known as galvanization, is applied to prevent the surface from oxidizing or corroding. This process is done by coating the part in a flux and dipping the part into molten zinc. The molten zinc forms a bond with the steel, creating a protective layer on the surface of the part.
