Vapor Polishing
N/A
Applications
Enhanced cosmetic appearance, near optically clear applications
Smooth and glossy
Vapor polishing is a manual process that uses a vaporized solvent to melt the surface of the material so that it flows and fills in microscopic scratches or voids. The surface is polished at a microscopic level and no material is lost in the process, similar to vapor smoothing for 3DP.
This process results in a near optically clear surface finish and is commonly used in applications where high levels of transparency are required.
Design considerations
  • Parts with uniform wall thicknesses will generally smooth more evenly
  • Radiused corners generally produce better results than sharp corners
What is Nearshoring and Why are Companies Moving Their Manufacturing Closer to Home?
Your manufacturing partner and their location are critical factors to consider when it comes to part production. Many companies that outsource manufacturing or own factories overseas are nearshoring due to several advantages such as reduced lead times, improved communication and cost savings. Nearshore manufacturing is a trending topic in the U.S. due to these benefits […]
