Hand Polishing
N/A
Applications
Enhanced cosmetic appearance
Smooth and glossy
Hand polishing is a manual process where the part is sanded, then buffed on a set of abrasive wheels or rouges to achieve the desired surface finish. This is a subtractive process that removes material in order to eliminate scratches and other imperfections.
Design considerations
  • Radiused corners and edges generally produce better results than sharp ones
  • Wall thicknesses less than 1.5mm do not hold up as well during polishing
  • Internal or hard to reach features (including threads) are difficult or impossible to polish
  • Very tight tolerances, reamed holes, and threads may need to be excluded from polishing
Artificial Intelligence (AI) is transforming various industries, and mechanical engineering is no exception. When I started working as a mechanical engineer 13 years ago, I didn’t think much about AI someday replacing my job. Now, with the recent hype around AI, many of us in product development, engineering, and manufacturing have considered how AI affects […]
