Finishing Services
Electropolishing
n/a
Smooth, glossy finish
Can be applied with
Passivation, Tumbling
Electropolishing is an electrochemical process used to improve the surface finish of a part by removing material to level microscopic peaks and valleys. This process can polish, passivate, and deburr the parts. This process works the opposite way than that of plating processes, as the part acts as the anode in the reaction. As the current passes through the part (anode), the surface is oxidized and dissolved in the solution to the cathode.
Electropolishing is very useful in polishing irregular parts with hard to reach surfaces. Additionally, only a small amount of material is removed, so tolerances will not be greatly affected by this process.
What is Nearshoring and Why are Companies Moving Their Manufacturing Closer to Home?
Your manufacturing partner and their location are critical factors to consider when it comes to part production. Many companies that outsource manufacturing or own factories overseas are nearshoring due to several advantages such as reduced lead times, improved communication and cost savings. Nearshore manufacturing is a trending topic in the U.S. due to these benefits […]
Producing Show-Quality Mockups for CES 2025: Top Manufacturing Processes to Elevate Your Prototypes
The Consumer Electronics Show (CES) is the ultimate stage to showcase innovative technology and futuristic designs. High-quality mockups are essential to captivate an audience and stand out in the crowded exhibition halls. Whether you’re unveiling groundbreaking consumer tech or sleek new designs, the manufacturing process you choose for your prototypes can make or break your […]
