CNC Prototyping Services
Precision, quality, and efficiency — our state-of-the-art machinery and highly skilled team will exceed your expectations.
Join 3,200+ companies who work with Fictiv
icon
ISO 9001 certified,
AS 9100 / ISO 13485 compliant
icon
Parts as Fast as 2 days
icon
Hand Metrology,
Laser & CMM Inspections
icon
45+ Certified Materials,
13+ Finishing Options
Trusted by Industry Leaders Nationwide
Confidentiality Assured with NDAs
We understand the importance of safeguarding your confidential information. Rest assured, we gladly accept Non-Disclosure Agreements (NDAs). Submit an inquiry here, and we will follow up with an email providing the next steps.
Our CNC Machining Services
CNC Milling
3, 4 and 5-axis machining capabilities for simple and complex geometries.
Part size: up to 48” in length
Tolerance: as tight as +/-0.008 mm,
ISO 2768 Medium without a drawing
Materials: 45+ metal and plastic options
Finishes: 13+ finishing options
CNC Turning
Standard and live tooling capabilities for cylindrical parts such as pins, shafts, and spacers.
Electrical Discharge Machining (EDM)
Wire and Sinker EDM are non-contact machining methods for cutting deep pockets, complex internal features, and holes with a keyway.
Min part size: 3.0x3.0x0.3mm
Max part size: 300x300x200mm
Tolerance: ISO grade 7 to 12
Materials: 26+ options
Gear Hobbing
A wide range of stock hobbing tools available for quick turnaround times.
Min part size: 1.0x1.0x0.3mm
Max part size: 500x500x800mm
Tolerance: ISO grade 6 to 12
High-Volume CNC Machining
Serving all your CNC needs up to production quantities, including finishing and machining—all from your 2D drawings.
CNC Machining Materials
ABS
Acrylic
Aluminum
Brass
Bronze
Cast Iron
Copper
Delrin
Garolite G-10
HDPE
Invar
Kovar
Magnesium
Nylon
PEEK
Polycarbonate
Polypropylene
PPS
PTFE
PVC
Stainless Steel
Steel
Titanium
Tool Steel
Torlon
UHMW
Ultem
Zinc
ABS
ABS (Acrylonitrile Butadiene Styrene) is an affordable thermoplastic that has become popular for pre-injection molding prototypes. It is a versatile material known for its strength, durability, and resistance to impact and heat. ABS plastic is widely used in the automotive and consumer electronics industries due to its excellent mechanical properties and ease of processing. Additionally, it can be easily modified with other additives to enhance specific properties such as flame retardancy or UV resistance.
Mill Lead Time:
As fast as 3 days
Colors:
Black, neutral matte finish
cnc machining abs plastic part
Precision Machining Tolerance
Metals, PEEK, And
ULTEM With Drawing
Other Plastics
With Drawing
No Drawing
Linear Dimension +/- 0.01 mm
+/- 0.0003 inch
+/- 0.05 mm
+/- 0.002 inch
ISO 2768 Medium
Hole Diameters
(Not Reamed)
+/- 0.008 mm
+/- 0.0003 inch
+/- 0.05 mm
+/- 0.002 inch
ISO 2768 Medium
Shaft Diameters +/- 0.004 mm
+/- 0.00016 inch
+/- 0.05 mm
+/- 0.002 inch
ISO 2768 Medium.
Part lengths of up to 48" available on our platform, process dependant. Please inquire about anything larger. Tolerances listed here are minimums for an ideal case. Looser tolerances may be required depending on process, material choice, or part geometry.
Download CNC Material Datasheet
Unrivaled Service Delivers High-Quality Parts at Incredible Speeds
Real people, here to help
Technical manufacturing and quality experts support you every step of the way, from quote to fulfillment.
Faster parts, no sacrifices
Program managers advocate for your design requirements during production, managing issues and logistics to keep schedules on-track.
Expert DFM guidance
Our best-in-class design for manufacturability feedback and guidance means your parts are high-quality AND cost-effective.
Quality you can count on
Every part we deliver is verified by Fictiv inspectors, and we conduct manufacturing facility audits to maintain high production standards.
CNC Machining FAQs
icon chevrond down
Fictiv provides a variety of lead times to match your budget while maintaining your project timeline. We can supply CNC parts in a quick as two days.
icon chevrond down
Our machines are capable of tolerances as tight as 0.0002"
What types of materials can your CNC machines work with?
icon chevrond down
Our instant quoted materials can be found (here). Not seeing what you are looking for? You can always request a custom material through our custom RFQ process. Help center
icon chevrond down
Fictiv is SOC 2 Type II certified (SOC 2) and our proof of certification can be supplied upon request.
Can you accommodate rush orders or expedited delivery?
icon chevrond down
Speed is standard at Fictiv, we work to present you with a variety of costs and lead times to match your requirements. However, if you do require even faster delivery for a specific quotation, please reach out to your sales representative to see if we can accommodate your request.
Do you have the capability to work with complex geometries or 2D Drawings?
icon chevrond down
Fictiv not only supports complex geometries, but we pride ourselves on being able to produce and deliver difficult parts. Our platform allow for 2D drawing upload, 2D drawing generation and our quoting engine analyzes the drawings for configuration details and special callouts.
icon chevrond down
Our platform provides free Design for Manufacturability (DFM) feedback pre-order on all quotations. There are two categories of this feedback. A Warning designates a piece of the design that you should have a second look at, but can still proceed with ordering the part as is. If you receive a Failure, it designates that the component has a significant risk of failure during manufacturing and a design revision must be uploaded in order to check-out.
icon chevrond down
Fictiv is ISO 9001 certified, AS 9100 and ISO 13485 compliant
