Zinc Plating
Clear: light blue coating; Black: glossy black coating
Smooth finish, does not hide machine marks
Can be applied with
Media Blasting, Tumbling, Passivation
Color Options
Zinc Plating Black Zinc Plating
Black Zinc Plating
Zinc Plating Clear Zinc Aluminum
Clear Zinc Aluminum
Zinc plating, which is also known as galvanization, is applied to prevent the surface from oxidizing or corroding. This process is done by coating the part in a flux and dipping the part into molten zinc. The molten zinc forms a bond with the steel, creating a protective layer on the surface of the part.
When designing a product, you want to consider all the factors that will go into its success over the course of the development process. For most companies, this involves making the best quality product at the lowest possible cost. Design for Excellence (DFX) is a modern product development approach and umbrella term that encompasses several […]
CNC Machining Coolants and Cutting Fluids: Types, Benefits, and Best Practices
If you’ve ever seen a CNC machine operate, you know it’s loud, hot, and fast. Managing heat and friction in CNC machining is critical to maintaining precision and tool longevity. Excessive heat, primarily generated by friction between the cutting tool and the workpiece, can lead to premature tool wear, poor surface finishes, and even material […]
