Electroless Nickel Plating
n/a
Smooth, glossy finish
Can be applied with
Alodine
Electroless nickel plating (ENP of NiP) is a reaction that deposits a nickel-phosphorus alloy onto the surface of a metal. It uses a purely chemical reaction to induce plating and does not leverage electricity. Though this process takes much longer than electroplating, advantages are a more uniform thickness over even the most complex surfaces (due to not having to rely on varying electric fields), as well as superior wear and corrosion resistance. The standard specification for ENP in North America is MIL-C-26074E, with various grades specifying thicknesses from 0.0003-0.002”.
Design considerations
Our standard offering for ENP adds thickness between 0.0003”-0.0005”, although we can achieve 0.00005” up to 0.002″ if specified in a drawing.
What is Nearshoring and Why are Companies Moving Their Manufacturing Closer to Home?
Your manufacturing partner and their location are critical factors to consider when it comes to part production. Many companies that outsource manufacturing or own factories overseas are nearshoring due to several advantages such as reduced lead times, improved communication and cost savings. Nearshore manufacturing is a trending topic in the U.S. due to these benefits […]
