Latest articles
IM Quotes in Hours, Not Days
Fictiv is your trusted partner for precision injection molding from prototype to production. Now, Fictiv is the first to provide instant DFM feedback along with our normal guided expertise and full project DFM with each quote. Fictiv can provide many of your injection molding quotes in hours rather than days. Our team has the industry’s […]
Tariff Notes:  Strategies for Tariff-Proofing your Supply Chain
In light of the big shift we will see on January 20th, 2025, with the 47th President re-taking the helm and a slew of Executive Orders forthcoming, I decided to sit down and talk to our Logistics Chief here at Fictiv, Mr. Vinny Licata.  I wanted to understand how we might help our customers navigate […]
What is Nearshoring and Why are Companies Moving Their Manufacturing Closer to Home?
Your manufacturing partner and their location are critical factors to consider when it comes to part production. Many companies that outsource manufacturing or own factories overseas are nearshoring due to several advantages such as reduced lead times, improved communication and cost savings. Nearshore manufacturing is a trending topic in the U.S. due to these benefits […]
The advent of CAD systems, additive manufacturing, and CNC machining have made the design and manufacture of complex part designs almost routine. Engineers today are tasked with designing components that may be subjected to a variety of factors, including extreme weather conditions, chemicals, bodily fluids, high stress or loads, impacts, and other elements that could […]
Tips to Reduce Injection Molding Costs
What’s the best way to achieve low-cost injection molding? The first step is to identify and understand the sources of your expenses. Next, it’s critical to make cost-saving decisions as early as possible in the design process to avoid getting locked into a course of action that’s difficult and expensive to change later on. Discussed […]
Fictiv’s New Mold Library
All of Your Tools. All in One Place. As the number of your Injection Molding tools grows, it can be a very time-consuming (and manual) process to ensure you’re getting the best return on your investments. That’s why we created Fictiv’s Mold Library: To give you one place to see all of your tools and […]
Fictiv Launches Nearshoring Solution for Production Injection Molding
OEMs can source economical steel tools manufactured overseas and shipped to Mexico for reliable, nearshore production—seamlessly through Fictiv’s global manufacturing network. Fictiv, a global manufacturing company, provides a hybrid injection molding solution for original equipment manufacturers (OEMs) who need the best possible tooling craftsmanship for reliable nearshore production. Through Fictiv’s global manufacturing network, OEMs can […]
Producing Show-Quality Mockups for CES 2025: Top Manufacturing Processes to Elevate Your Prototypes
The Consumer Electronics Show (CES) is the ultimate stage to showcase innovative technology and futuristic designs. High-quality mockups are essential to captivate an audience and stand out in the crowded exhibition halls. Whether you’re unveiling groundbreaking consumer tech or sleek new designs, the manufacturing process you choose for your prototypes can make or break your […]
Chem Film, Anodizing, and Black Oxide: Which Conversion Coating is Right for Your Project?
‍When metal is exposed to the elements or certain chemicals, deterioration in the form of oxidation may occur. The Second Law of Thermodynamics declares that everything tends to move into a state of disorder. After designing and manufacturing your products, the last thing you want to discover is a breakdown of a metal component in […]
Symbol Geometric Characteristic Description Typical Use Case Integration in CAD Inspection Notes ⏤ Flatness Ensures a surface is uniformly flat within the specified tolerance. Critical for sealing surfaces or bearing fits. Applied using surface tools for flatness analysis. Checked with a surface plate and gauge. ⊥ Perpendicularity Ensures a surface or feature is at 90° […]
