3D Printing Materials
PA 12 Glass Beads
Process
HP® Multi Jet Fusion
Production Time
As fast as 5 days
Colors
Grey, black
Resolution
0.08 mm
Price
Applications
End-use production parts, Functional prototypes,
Max Print Size
380 x 284 x 380 mm
About the Material
PA 12 (Polyamide 12) with glass beads is a 3D printing material that combines the properties of PA 12 with added glass beads. This combination enhances its strength, stiffness, and thermal stability. Here are some common applications for PA 12 with glass beads in 3D printing:
Engineering Prototypes: PA 12 with glass beads is often used to create engineering prototypes of parts and components that require high mechanical performance, such as gears, brackets, and housings.
Functional Parts: It is suitable for producing functional parts that need to withstand mechanical stress and maintain their dimensional stability under load.
Automotive Components: This material can be employed in the production of automotive components, including under-the-hood parts, engine components, and structural elements.
Aerospace Components: PA 12 with glass beads can be used in aerospace applications for producing components that need to meet strict performance and safety standards.
Tooling and Fixtures: Manufacturers use this material to create custom tooling, jigs, fixtures, and assembly aids that require durability and dimensional stability.
Custom Manufacturing Tools: It is used to produce custom manufacturing tools and molds for various industries, including injection molding and metal forming.
Electrical and Electronic Components: PA 12 with glass beads is suitable for manufacturing electrical insulators, connectors, and housings for electronic devices.
Oil and Gas Equipment: In the oil and gas industry, this material can be used for producing components that must withstand harsh environmental conditions and chemicals.
Marine Applications: Due to its resistance to moisture and chemicals, it can be used to create components for marine equipment and vessels.
High-Temperature Applications: It is used in applications exposed to high temperatures, such as exhaust system components and heat-resistant fixtures.
Chemical Resistant Parts: PA 12 with glass beads is resistant to many chemicals, making it suitable for parts exposed to corrosive substances.
Low-Wear Components: Parts requiring low wear and high dimensional stability, such as conveyor system components, can be manufactured from this material.
Structural Components: In industrial equipment and machinery, this material can be used for producing structural components and load-bearing parts.
Water-Resistant Parts: Its resistance to water absorption makes it useful for applications exposed to moisture or humidity.
Custom Valve Components: Valve components and seals can be manufactured from PA 12 with glass beads due to its combination of strength and chemical resistance.
Bearings and Bushings: The material’s low friction coefficient makes it suitable for producing bearings, bushings, and sliding components.
Medical Device Prototypes: It can be used in the prototyping of medical devices that require both strength and biocompatibility.
Consumer Products: Some consumer products, especially those requiring durability and resistance to wear, can benefit from this material.
PA 12 with glass beads is chosen for applications where superior mechanical properties, thermal stability, and resistance to wear and chemicals are required. It is particularly well-suited for demanding industrial and engineering applications.
Process
MJF
Tensile Strength
30 MPa (4351 PSI)
Elongation at Break
10%
Modulus of Elasticity
2500 MPa (362594 PSI)
Flexural Strength
57.5 MPa (8340 PSI)
Material Datasheet
Material Finish
The texture of this material is slightly smoother than SLS Nylon, but still similar to a very fine grit sandpaper. Un-dyed MJF Nylon is grey, which may vary in shades across the same part of a surface. When dyed black, this material has a matte appearance.
Design Recommendations
Max Part Size [x, y, z]
380 x 284 x 380 mm
Min Wall Thickness
1.0 mm for production
1.5 mm for consistency (for measurement and mechanical applications)
Min Clearance + Gaps for Fit
0.2 mm clearance between features, we recommend 0.3 mm to ensure good fit
Internal Cavities
Be sure to have a clearance to remove the support powder!
Threads & Inserts
Minimum 0.1 mm clearance is required for printed threads.
Text Guidelines
Raised features: 0.6 mm minimum
Recessed features: 0.5 mm minimum
Medical Device Manufacturer Uses Fictiv to Clear 18-month Backlog in 4 Months
The Economics of Injection Molding vs. 3D Printing
Learn how to compare the cost of 3D printing vs injection molding from Fictiv. This article includes a cost analysis and case study.
