3D Printing Materials
RPU 70
Process
Carbon DLS
Color
Black
Resolution
0.075 mm
Max Print Size
189 x 118 x 326 mm
About the Material
RPU 70 thumbnail graphic
RPU 70 is a stiff and strong material used across a wide range of industries, including consumer products, automotive, and industrial. RPU 70 has a UL 94 HB flame resistance classification. RPU 70 is comparable to ABS.
Ultimate Tensile Strength
40 MPa / 6000 PSI
Elongation at Break
n/a
Heat deflection temperature
60°C / 140°F @ 0.45 MPa
Producing Show-Quality Mockups for CES 2025: Top Manufacturing Processes to Elevate Your Prototypes
The Consumer Electronics Show (CES) is the ultimate stage to showcase innovative technology and futuristic designs. High-quality mockups are essential to captivate an audience and stand out in the crowded exhibition halls. Whether you’re unveiling groundbreaking consumer tech or sleek new designs, the manufacturing process you choose for your prototypes can make or break your […]
Medical Device Manufacturer Uses Fictiv to Clear 18-month Backlog in 4 Months
