CNC Machining Materials
Invar
Processes
CNC Mill
CNC Lathe
Lead Time
As fast as 7 days
Finishing Options
Vibratory Tumbling, Media Blasting, Powdercoating
Tolerance
No drawing: ISO 2768 medium
About the Material
Invar 36 is a nickel-iron alloy with excellent dimensional stability at a wide range of temperatures. The ’36’ stands for the alloy containing 36% nickel and has a super low coefficient of expansion.
Invar 36
Yield Strength (tensile)
40,000 PSI
Elongation at Break
30%
Hardness
Rockwell B90
Density
8.05 g/cm^3
0.29lb / in^3
Material Finish
Invae 36 is very similar to most grades of steels/stainless steel in terms of overall appearance. Invar can be media blasted or tumbled to achieve a multitude of surface finishes. Additionally, powder coating can be applied to achieve more matte/glossy colors.
Design Recommendations
Min Wall Thickness
0.5 mm (0.02 in)
Min End Mill Size
0.8 mm (0.03 in)
Min Drill Size
0.5 mm (0.02 in)
Max Part Size
1200 x 500 x 152 mm [x,y,z] (mill) 152 x 394 mm [d,h] (lathe)
Undercuts
Radii : Depth
Depth must not exceed 12x drill bit diameter. For end mills, depth must not exceed 10x tool diameter.
Cost Saving Tip
Medical Device Manufacturer Uses Fictiv to Clear 18-month Backlog in 4 Months
CNC Machining Outsourcing: Fictiv’s Detailed Guide
CNC machining outsourcing is a manufacturing strategy that involves contracting with another company for CNC machining services. Whether for prototyping or production, product designers who outsource their machined parts gain access to advanced technology, leverage custom machining solutions, and avoid expensive investments in equipment and training.  This guide provides an overview of computer numerical control […]
