Content type
Role
Topic
Manufacturing Processes
Latest articles
Precision Grinding: Processes, Tolerances, and When To Use It
Most engineers have a solid feel for what CNC machining can do. But far fewer have a clear picture of what to do when conventional CNC process capabilities are exceeded by the need for tighter tolerances, finer surface finishes, or hardened work material that quickly wears through machine tools. When that happens, manufacturing engineers move […]
CNC machining is commonly used to manufacture various medical devices—surgical instruments, fixtures, structural elements, fluid-handling parts, and components that attach to or form part of a tissue-contacting implant. The machining operations themselves are familiar shop-floor work. The practical difference in medical device machining is that material definition, surface condition, traceability, inspection, and documentation aren’t just […]
MISUMI Americas Launches MISUMI Ventures, a $50 Million Fund Backing the Next Generation of Hardware, Robotics and Physical AI Companies
Silicon Valley–based fund advances MISUMI Group’s $1B Global Investment Vision and gives founders day-one access to a Fortune 500–caliber global manufacturing supply chain OAKLAND, CA and TOKYO, Japan – September 17, 2026 – MISUMI Americas, a specification-driven sourcing partner for mechanical components and assemblies, today announced the launch of MISUMI Ventures, a $50 million venture […]
Flame-Retardant Plastics and UL 94: A Practical Guide for Engineers
Flame-retardant requirements show up in power supply housings, electrical connectors, and industrial control panels. They also turn up in products like a battery pack on a mobile robot, a diagnostic device housing, or a solar inverter enclosure. Any product with a battery, power electronics, or components near line voltage is a candidate for a flammability […]
New
Fictiv Named One of Fast Company’s 2026 Best Workplaces for Innovators
Fictiv recognized in the Industrial and Manufacturing category for fostering a culture of innovation Oakland, Calif. – September 8, 2026 – Fictiv, a global manufacturing and supply chain company and a division of MISUMI Americas, today announced it has been named a winner in the Industrial and Manufacturing category of Fast Company’s 2026 Best Workplaces […]
Food-Grade 3D Printing and Manufacturing: How to Choose the Right Process and Material
When a customer came to Fictiv needing 3D-printed components for a shrimp sorting machine, their first instinct was to quote nylon (PA) parts with Multi Jet Fusion (MJF). MJF produces strong, accurate nylon parts quickly and at a reasonable cost, making it a common solution for functional production components. The problem is that MJF produces […]
Sheet Metal Material Selection for Aerospace Applications
Choosing sheet metal for manufacture in aerospace isn’t just a matter of selecting the strongest or lightest alloy. For instance, a stronger material that suits machined components may crack during bending, while one that forms easily may lack the fatigue strength for vibration-loaded structures. An apparently suitable alloy may fail in salt spray, elevated temperatures, […]
Prototyping with Casting: Die, Investment, and Gravity Mold Processes
Most prototyping conversations center on CNC machining and 3D printing, and for good reason: both provide parts fast, which is a real advantage for early design work. Once a metal component is headed toward production casting, however, these prototyping methods don’t fully represent the manufacturing conditions and final product. Using the same process for prototypes […]
