round check mark
ISO 9001:2015 certified QMS
round check mark
45+ Certified Materials, 13+ Finishing Options
round check mark
NADCAP and NABL approved manufacturing partners
round check mark
Hand Metrology, Laser & CMM Inspections
round check mark
Hardware Installation & Mechanical Assembly
Drawings Reconciliation—
for Clarity During Quoting
Drawings Reconciliation is your automated assistant that parses uploaded drawings, maps requirements to part configurations, and flags conflicts before checkout.
  • 1. Automated drawing configuration
  • 2. Simplified discrepancy reviews
  • 3. Pre-order requirement validation
  • 4. Fewer fulfillment bottlenecks
Get an Instant Quote & Instant Resolution Today
Our CNC Machining Services
Why Fictiv for CNC Machining
Sourcing simplified for custom CNC Machining
Made As Fast As 1 Day
  • list check mark Pre- & Post-Order DFM
  • list check mark Large Parts (Up to 34 feet)
  • list check mark No Minimum Order Quantity
  • list check mark Tight Tolerances (+/- 0.0001”)
  • list check mark Wide Range of Metals and Plastics
  • list check mark Finishing Options (Anodize, Plate, Chem Film)
  • list check mark High-Quality, Complex Geometries
  • list check mark Undercuts, Threads & Holes
cnc machining
Precision Machining Tolerance
Metals, PEEK, And
ULTEM with Drawing
Other Plastics
with Drawing
No Drawing
Linear Dimension +/- 0.0025 mm
+/- 0.0001 inch
+/- 0.05 mm
+/- 0.002 inch
ISO 2768 Medium
Hole Diameters
(Not Reamed)
+/- 0.0025 mm
+/- 0.0001 inch
+/- 0.05 mm
+/- 0.002 inch
ISO 2768 Medium
Shaft Diameters +/- 0.0025 mm
+/- 0.0001 inch
+/- 0.05 mm
+/- 0.002 inch
ISO 2768 Medium
Part lengths of up to 48" are available on our platform process dependent. Please inquire about anything larger. Tolerances listed here are minimums for an ideal case. Looser tolerances may be required depending on process, material choice, or part geometry.
CNC Machining Materials
A2 Tool Steel
ABS
Acrylic Machining Services
Brass
CNC Aluminum
Copper
Delrin
HDPE
Invar
Kovar
Machining Bronze
Machining Cast Iron
Machining Garolite G-10
Magnesium
Nylon
PEEK
Polycarbonate
Polypropylene
PPS
PTFE
PVC
Stainless Steel
Steel
Titanium
Tool Steel
Torlon
UHMW
Ultem
Zinc
A2 Tool Steel
Mill Lead Time:
As fast as 7 days
Finishing Options:
Try Materials.Ai
MaterialsAI
Finishing Options for CNC Machining
Chem Film Aluminum Clear, gold Media Blasting, Tumbling, Type II Anodizing* Type III Anodizing with PTFE*
Anodizing Aluminum Clear, black, grey, red, blue, gold Media Blasting, Tumbling, Chem film*
Electroless Nickel Plating Aluminum, Steel, Stainless Steel — Media Blasting, Tumbling
Electropolishing Steel, Stainless Steel — —
Hand Polishing Acrylic — Enhanced Cosmetic Appearance
Media Blasting Aluminum, Steel, Stainless Steel, Brass, Bronze, Copper — All post processes, except Electropolish and Powder Coat
Passivation Steel, Stainless Steel — Black Oxide, Electroless Nickel Plating, Zinc Plating, Tumbling, Media Blasting
Powder Coating Services Aluminum, Steel, Stainless Steel Full Pantone or RAL color catalog —
Tumbling Aluminum, Steel, Stainless Steel, Brass, Bronze, Copper — All post processes, except Electropolish and Powder Coat
Vapor Polishing CNC Polycarbonate (Clear, Black) — Enhanced Cosmetic Appearance, Near Optically Clear Applications
*Additional finishing options include chromic acid anodizing, cadmium plating, copper plating, titanium anodizing (blue anodizing), gold plating, silver plating, and more. For materials not listed here, please contact us directly.
Download our CNC Design Guide!
Learn how to control costs, streamline the design and machining process, and ensure quality CNC drilling, milling and turning outcomes.
Download
WORKFLOW AUTOMATION
#fictivmade
Custom CNC Machining Parts Made By Fictiv
JOE TEDESCO
Production at the pace of innovation.
JOE TEDESCO
Lead Aerospace Engineer
Heliospace
Download Case Study >
Brian Burns
30% lower overhead costs.
Brian Burns
Co-Founder,
Catalyst Engineering
CNC Machining Service FAQs
Fictiv provides a variety of lead times to match your budget while maintaining your project timeline. We can supply CNC parts as quickly as one day.
Our machines are capable of tolerances as tight as +/- 0.0001 inches.
What types of materials work with your CNC machining services?
Our online instant quoted materials can be found here. Not seeing what you are looking for? You can always request a custom material through our custom RFQ process.
At Fictiv, we know how critical information security is, especially when working with high-value design IP. That's why we designed our platform with elite-level security and confidentiality as a top priority. From log in to file upload to part fulfillment, you can rest easy knowing that your IP is safe within our secure Digital Manufacturing Ecosystem. Need extra assurance? We're happy to sign an NDA, simply fill out a request here.
Can you accommodate rush orders or expedited delivery for CNC machining?
Yes. Speed is the standard at Fictiv, but never at the expense of quality. We offer a variety of costs and lead times to match your requirements. However, if you require faster delivery for a specific quote, please reach out to your sales representative to see if we can accommodate your request. We will do everything we can to achieve your desired timeline.
Are you able to work with complex geometries or 2D drawings for CNC?
Fictiv not only supports complex geometries, but we pride ourselves on being able to produce and deliver complex parts. Our online manufacturing platform enables 2D drawing uploads and generates 2D drawings. Our quoting engine then analyzes the drawings for configuration details and special callouts.
Our platform provides free Design for Manufacturability (DFM) feedback pre-order on all quotations. There are two categories of this feedback: 1. “Warning” indicates a design that requires a closer look, but can still proceed with ordering. 1. “Failure” indicates the component has a significant risk of failure during manufacturing. In this case, a design revision must be uploaded prior to check-out. We also have a team of engineers available to provide DFM feedback via email or phone.
Fictiv is ISO 9001 certified, ISO 13485 compliant, and has NADCAP and NABL approved manufacturing partners.
Get Custom Parts Delivered As Fast As 24 Hours.
Instant pricing & lead-time options
Learn More About CNC Machining
ARTICLE
Designing Structural Links for Robotic Arms: Materials and Design for Manufacturing
A robot arm can assemble cleanly, pass every bench check, and still miss its target in the field. The problem…
Read more >
ARTICLE
Choosing the Right Stainless Steel for Your Manufacturing Program
Picture a food mixing agitator that runs fine for a year. Then salty product and the daily sanitizing cycle find…
Read more >
ARTICLE
Metal Material Selection Guide: Choosing the Right Alloy for CNC Machining and Sheet Metal Parts
Picking a metal for a custom part is one of the most critical decisions you’ll make in the design process.…
Read more >
